Strat Avenger
I know this is an old topic that has already been discussed here, but I just wanted to share my satisfaction here.
I built my Warmoth a couple years ago, It has a 10"-16" compound radius neck -- the first I've ever owned. The Floyd Rose bridge has a 10" radius (not 12", as some have stated). I knew about saddle shims, but was just too lazy to deal with it...until tonight. I never liked how the B, G, and D strings were so high off the fretboard past the 10th fret. Well, problem solved. I bought 6 shims from AXcessories.com that are .2mm in thickness. I installed 2 under the high E and low E, one under the B and A, and then lowered the entire bridge. I am very pleased with the results. The guitar plays wonderfully now. I was not interested in making my own shims from cutting up a soda can or other method. These shims are specifically made for Floyd Rose saddles, and have a hole for the Allen screw to go through, which keeps them perfectly positioned under the saddle.
I highly recommend these shims if you are using a Ffoyd Rose bridge, and have anything flatter than a 12" radius fretboard.
:guitaristgif:
:guitaristgif:
