Mayfly said:
Yes, but the implementation is a little clunky. It's a press-and-hold some dual-purpose switch thing, and if you're willing to wait for that to have an effect, you probably also have time to just switch presets, which to me would be more intuitive. It might be possible to use an external switch assigned to that function, but I'm not familiar enough with the unit to say for sure. Mayfly's got an AX8 - maybe he's found a way to do it.
X/Y is changeable with a scene change. that is, instantaneous.
That is correct for X/Y and probably the best way to use it on the AX8 (or the FX8 for that matter). Set up your preset (or virtual rig) and use scenes to go between various permutations for clean, crunch, lead, ambient shoegaze etc...
@macegtr thanks for posting a picture of your preset. I am somewhat familiar with Axe-Edit, being a former Axe FXII user. I have heard of that Taylor IR and it sounds very good. I guess you are using the "Tube Pre" to give a little warmth before it hits the iR. (I think Alex Lifeson also does something similar and may use the same IR but I am not certain on the IR).
The AX8 could run the Piezo part or the other part of the preset, but not both together however for the reasons pointed out be Cagey.
As for me at the moment when funds allow I may get another Fractal, I have since gone back to tube amps, and am on the fence of building up a pedalboard (I have some nice drives from Keeley and Suhr) but all the time-based stuff and compression I no longer having sold it when I went digital. I am leaning towards a combination of analog into the front end and possibly something Fractal in the loop of the amp. Helix is another option but I would need to try one. The FX8 may be an option but seems limited on the MIDI side.
