RiverCity28
I'm new to this board . . . thanks for all the great information I'm finding here!
This telecaster style guitar is my first build (or assembly, if you like). It has a Glendale stainless steel bridge with Glendale saddles ("Twang" set with Aluminum E/A, and brass D/G and B/E). Callaham prewired control plate assembly (cryogenically treated, like this really matters), locking Schaller tuners, Lollar Special T pickups, and Glendale "cold rolled steel" chrome plated string ferrules (what they call the"Redd Volkaert" set).
Since this is my first shot at soldering, I thought I keep the electronics simple by purchasing a mostly pre-assembled control plate. I just need to solder the pickups to the three-way switch/ground; and also solder the jack. I'm building a neck jig so I can level and dress the frets, which are 6150s mounted on a Warmoth Pro boattail neck. The neck arrived unfinished from Warmoth and I applied a Birchwood Casey gunstock oil and wax job. My MusicMan Axis BFR has this same finish and it feels GREAT! As you can see below, the maple neck has great flame. The Warmoth body is alder with a tobacco burst quilt maple top.
I have a number of small things to do including shaping the pickguard a bit better on the lower horn; tweaking the nut height; and finishng the final setup. I hope to finish it this weekend!
Here are a few photos . . .
