TonyFlyingSquirrel
Master Member
Like a volume pedal, but without the treadle.
You "preset" the volume you want to drop to. It allows hands free operation so you can keep playing without having to adjust your guitar's volume knob to find the sweet spot. Set the sweet spot on the floor, hit it consistently every time.
Features:
True Bypass
Treble Bleed Circuit for treble clarity at lowered volume.
Completely Passive, Battery is only used to power led light, independent from sonic path.
Small footprint on the pedal board.
Rim-Light indicator. Bottom plate is made of Acrylic, Led is internal and creates a rim of light around the bottom of the unit indicating active or inactive. No "Dot" shining from the top right into your eyes.
Features:
True Bypass
