2ManyShoes
Getting ready to start a new build (a flying V) on Saturday. This is my third build, but my first Warmoth.
The body is mahogany with a flamed maple cap. The neck is maple with a Pau Ferro fingerboard. I'm going to dye the flamed maple cap with TransTint. The idea will be for the top of the cap to be Cordovan, and for the sides of the cap to be a natural masked binding that will match the back of the neck and the headstock. (Those parts will be plain maple, somewhat darkened by the Tru Oil.)
The color will be Cordovan (you can see it here: http://www.joewoodworker.com/images/transtints/cordovan.jpg), but first I'll do one coat of black dye to bring out the figure. I'll sand that back to clear wood and then proceed to the color.
The basic dye technique I picked up here: http://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=30182
Pickups will be Lindy Fralin PAFs (9k in the bridge, 8k in the neck, though I might switch those to a Grosh Blown '59 and a Lindy Fralin Unbucker). All hardware is black. I'll put pics up in the WIP section when I get rolling.
Anyway, here's my schedule for the body. I'd be happy to hear any comments or suggestions. Thanks.
1. Sand as necessary
2. Mask sides (including the “binding” created by the maple cap) with painter’s tape
3. Very light prep coat of Cordovan TransTint (so as not to shock the wood with black)
4. Let dry
5. One coat Black TransTint
6. Let dry
7. Sand down to clear wood
8. Cordovan TransTint
9. Let dry
10. Repeat as necessary until color is right
11. Light sand (if necessary)
12. Remove masking
13. Tru Oil (probably at least 10 coats, 24 hours apart, light sand with 0000 steel wool between coats)
14. Cure for 3-4 weeks
15. Carnauba wax
Thanks for any comments.
4. Let dry
6. Let dry
9. Let dry
12. Remove masking
15. Carnauba wax
