Cagey said:Red + Yellow = Orange. How much of each is almost infinitely variable. On that top, it was probably done all in yellow first, then some dilution of red added to the edges, which produces a reddish-orange result.
It pays to have a test piece or 3 to play with, so you can see your results and refine your mixtures/technique before you commit.
:laughing7: :laughing7:WWTD (What Would Tonar Do)
Tonar8353 said::laughing7: :laughing7:WWTD (What Would Tonar Do)
Well what I would do is use TransTint Lemon Yellow #6020B for the whole top and then burst it with TransTint Reddish Brown #6003.
Cagey said:If you use a water-based stain rather than alcohol, you get more time to play as water won't boil off at room temperature as fast as alcohol will. That allows you to rub around and fade things into each other more gradually. You can use water-based stains under solvent-based finishes as long as you give it plenty of time to dry thoroughly. You don't want any water trapped under the finish, unless your inventory of cuss words is low.
Also, if you're going to use water-based stain, wet down the surface before you start staining. That'll keep you from getting boundary marks where more or less stain gets absorbed.
