mrpinter
These three are my current favorite OD pedals (limiting this post to overdrives, not fuzz or distortions, which are different effects):
1. Earthquaker Devices Speaker Cranker. If you want just a simple effect to put some hair on your playing without fussing with a lot of knobs, and without coloring your tone excessively - this is your pedal. It has ONE control, a knob simply called MORE - the gain control. It isn't "transparent", but has a very natural tube saturation type of sound to it. One thing they've done I had an issue with however is to give the pedal a volume boost that increases with higher gain settings. Sometimes I want this, but sometimes don't want any extra boost if I just intend to lay back in the mix. So I had a simple master volume pot installed inside the pedal by an amp tech who does work for me occasionally. Here are pics of the pedal and the mod:
and a video demo: https://www.youtube.com/watch?v=rNK9UsfIAv8
2. Subdecay Super Nova Drive. A sleeper pedal you don't hear much about on the boards and there aren't many decent YouTube demos of it. It's been out for quite a while, and is very useful with it's three band EQ and it's underlying great tone and wide range from just a little drive to almost fuzz levels.
https://www.youtube.com/watch?v=qX8AmQzjmrg
3. Earthquaker Devices Chrysalis. A discontinued pedal you can still find new in at least one online effects retailer I know of, this pedal has it's own thing going on. While perhaps similar to a Tube Screamer type box, it's voicing is a bit different - it was designed to sound like 70s rock guitars as recorded on vinyl records. Strange as this may sound, it is an accurate enough description of it's sound. This thing CUTS.
https://www.youtube.com/watch?v=ubkAsmueh9Y
