O.K., I have gotten very used to the classic four-control Gibson setup, leaving the 3-way selector switch in the center and manipulating the two volumes. If you set your amp to sound it's best when both the guitar's volume knobs are at "7" or so, there's a whole world of sound in there. Just ask Duane Allman, Jimmy Page, Carlos & Eric (back when they sounded best, using Les Pauls :laughing3
and on and on. It's a very versatile setup once you're used to it.
I also use the bridge pickup's tone knob a lot, when you start with a fire-breathing Lawrence L500 pickup you'd better... but what I don't use is the neck pickup's tone control, it's always full up. So, I'm only using three knobs. But when I tried wiring a guitar up with that - just a volume control and no tone control on the neck pickup, and both tone and volume on the bridge pickup - it doesn't work right. The neck pickup's tone pot (500K) is doing something in there, even though it's all the way "open", supposedly.
On my upcoming Jagenstein (code name: "Peaches"), control space is going to be limited, at least in the first iteration. I would of course like to wire it with only three knobs. Is it as simple as just dropping the neck pickup's volume control down to a 250K pot, or wiring a resistor across the outside lugs or something? I understand the whole four-pot/two-pickup system is interactive (that's its joy) but I want to substitute some smaller component than a pot, since all it's going to do is sit there. I just don't quite understand what a 500K pot is, when it's not actively potting away.
