Ew, my neck is sticky
erogenousjones17
What can I do about a mahogany neck, finished about two years ago using Minwax satin wipe-on poly, that has recently started to feel really sticky and gross. Should I give it a light sanding and hit it with some more poly? Sand it more agressive and basically start over on the finish?
I'm with DMRACO, your dead skin is on that neck, boy! Either carry some 0000 Steel Wool with you everywhere you go (good for rosewood fretboards, and back of necks), or stop sweating!
I knock the gunk off my necks probably once a week. Overkill? Maybe
Groovy, thanks. I actually don't sweat too much, which I guess explains why it's taken two years for the neck to get gunky. The stickiness is also a lot worse in hot, humid weather. Is that weird?
