The Big Muff Pi has gone thru a bunch of changes.
The BEST ones, they say, are the transistorized ones, not the ones with 7431 (741 dually chips... think the # is correct).
If you have a 741 type... you can do a lot by changing out the ICs to highest grade, fast slew. Try Motorola if you can find 'em.
I dont remember a dual tone BMP, but there was one or two models that let you switch off the fuzz completely, and just use the tone knob as a tone shaper with no fuzz. That switch MIGHT have left a little dirt in the signal, but not much. I had one of those, and hardly ever used it.
The last BMP I got, a russian one... I ended up gutting, and building into a clone of the BluesBreaker pedal. Then I modded that one ever so slightly - turns out Marshall did to theirs too in the same way, except theirs is a dual range, whereas mine is just one (higher) range of grit. Those are more OD than fuzz, more to my tastes.
Another GREAT OD pedal is the visual sound Route 66 pedal - basically a tube screamer and compressor in one pedal. Very tasty
