Bob Hoover Ross
By "easiest" I mean...well, everything: Easiest to apply (especially), easiest to acquire, easiest to use in terms of the demands it makes on tools or infrastructure...
iow, I don't have a paint booth or a spray gun or experience (!) or even necessarily a well-ventilated space to work in; I live in a NYC apartment building. So a water-based wipe-on finish would probably be preferable just because that sounds to me like it makes the least demands on the refinishing job or on the refinisher (have I mentioned that I am completely inexperienced at doing any decent finish application?)
...but I need a finish with an effective UV block, because this is going on a Padouk body that I don't want to oxidize too badly.
Prefer a satin finish, in case that makes a difference. Prefer something that doesn't require a lot of sanding, but that's not a dealbreaker. Stinky chemical smells or dangerous outgassing definitely is a dealbreaker. Bonus points if someone can confirm that MinWax Wipe-On Poly contains UV block, just because I happen to have a can of that from another bass finishing project of mine.
Any suggestions? Thanks.
