I was removing the masking tape - after (almost) finishing the dye job on my project guitar.
I was careful and slow with removing the masking - but still lifted some of the dark cordovan dye job off the Alder side of the guitar - exposing underlying wood, slightly tinted wood. The lift spot was about .5" long, maybe one eighth wide, and very shallow. It appears to be only a thin layer of the dye that dryed on the surface and was pulled off - it is not down in to any actual wood.
Tried to get a picture but the camera just wouldn't focus on it.
I think I have 2 options. Since it appears that this was accumulated dye on the surface....
1. "Refill" the void with additional cordovan dye and sand flat. Using a brush - place dye in the lifted finish. Perhaps a couple passes to fill it in.
2. Tint some Wood Paste Filler and carefully fill the lifted finish spot. Try to get a color match and sand off as needed.
I'm inclined to do number 1 - since the finish lift spot appears to be built up dye anyway and it's the easiest. But, I think number 2 might be a "better" repair.
My questions:
1. Which option would you recommend?
2. If number 2 - Tinting some wood paste filler with dye - is there a brand of wood paste filler that is better than others for pre-tinting?
Thought I was done with the job - but I suppose this is further learning.
Thanks in advance.
EDIT: BTW - my question sort of begs the question of why a dye finish would "lift" and crack off without taking up wood. I used a super saturated mix of Cordovan Transtint dye - so I am guessing that there was so much color dye that it couldn't absorb and just set on the surface. That's just a guess. Any input on this question would be appreciated - but at this point I am most interested in the repair.
My questions:
Thanks in advance.
