Drilling neck mounting holes
Jeremiah
I'm thinking of trying to drill the mounting holes myself in a cheap (non-Warmoth) Strat neck.
I know the standard size is 1/8 inch, but it does not seem to be that easy to get hold of drills in inch sizes in the UK without buying an entire set of 120 or so bits.
1/8 inch =  3.175mm, so would 3mm be close enough? or should I go up to 3.5mm in case the 3mm hole is too tight?
i think you'd definitely want to stay smaller if anything. the 3 mm would be fine i would think. being off by only .175 of a mm isn't much at all. anyway somebody else may say otherwise, but i can't see that being much of a problem
