Double Strat Output jack?
Zaman
I could have sworn I saw a double jack plate for a Strat, but now I can't find it. Do y'all know if I'm imagining things? If I am, what's the best solution for two jacks on a Strat? Thanks.
how many solder lugs are there, there are many styles but i usually see plastic things with like 6 lugs.
I looked at the manual. It comes with a stereo jack. So I guess I'll use that and a Y-cable.
Y- cables are $40....  I know because my setup I run two of them!!  They get expensive to buy, so now I make them myself.
I can actually make you a double strat jack plate out of pickguard material or wood or I even have some thin aluminum plate here that I could make a jack plate out of for you.  PM me if interested.
You can use one of these on the side of the guitar, and run it into the jack hole on the strat,  there is enough room under a standard strat jack plate.  I put a TRS effects loop into a strat and that was how I did it, and it still looks like a strat from the front, only way you can tell is by noticing the extra cord coming out of the side when it is played.  I used a black jack in the side of a black guitar, it's invisible.
