Ddbltrbl
Some time ago I came into posession of a badly abused '78 Strat body. Some idiot used what might have been a dull straight-slot screwdriver to enlarge the bridge pick-up cavity to fit a humbucker.
Then, they broke thru into the trem cavity in one spot.
That made them really upset so they kicked the body, tearing a chunk out of it.
Then, they tried to force the remaining parts back into place with screws and nails.
You know, there really should be a special place in hell reserved for people this criminally ignorant!!
But, other than having the manditory 4 million chips and dings in the poly
and a place on the outside of the bottom horn that looks like they might have spilt Aircraft remover on it for a minute or so,
the rest of the body is in surprisingly good shape. :icon_biggrin: Honestly, I see no other damage thru to the wood.
So what does everyone think? Is it worth the effort to repair? If I fix the missing chunk, I would just have to match the black in one spot on the bottom to make it look original, or do I just strip it down and go with a complete refinish? :icon_scratch: And, should I try to fix the small break thru into the trem cavity and clean up the bridge pickup route, or just leave it alone?
I am thinking of putting a Warmoth neck on it if I do repair it, but I have the original neck. The poly is turning loose in spots and starting to flake, so it would have to be re-finished, but other than one small ding in the fret board at 17th fret low-E, the neck is in good shape. Anyway, I thought I might get a different perspective from the good folks here than I would from the Fender forum and would appreciate hearing what everyone thinks.
