spauldingrules
Okay, so I installed my Dimarzio Super Distortion in the bridge position of my strat, mounted directly to the wood. I think I found a good height - HOWEVER, like all of you, I like to tinker. How close do any of you like this pickup to your strings? It seems kind of far from the strings compared to what I am used to. I want the pickup to sound like it "should", and I'm afraid my ears are telling me to back it off the strings so it sounds more like the PAFs I am used to. This is my first "hot" pickup - ceramic magnet, etc. "Should" these be closer or further to the strings than a normal PAF? I know it's a matter of taste, blah blah blah, but what has been proven to work for these pickups? I'm going for classic rock sounds, not extreme metal. It sounds a little "treblier" than I expected - does closer or further from the strings make it "fatter?" I don't want to experiment too much since it is mounted directly to the wood, so I would like your opinions please.
Oh, and I got the "Humbucker from Hell" in the neck position and this is the BEST NECK HUMBUCKER EVER! I love it! I have a set of Duncan 59's which were my fave, however the HFH is just plain articulate like a neck single coil except with humbucker-type sound. Such a pleasant surprise! Easy to switch to "clean" just by switching to it from the Super Distortion. Just so round and full but not muddy at all. I was going to get a PAF type but I'm glad I didn't.
I've only played it through my Epi Valve Junior head/cab. Sounds good with and without my tube screamer knockoff.
Thanks in advance - pix of the new build will be following shortly.
- TS
- TS
