1. go to Radio Shack, buy one of the green ones. .047 uf is good. solder it in - one side goes to ground.
2. while you're there get a multimeter. Bout twenty bucks. Check all the connections to make sure you don't have any cold solder joints. Your soldering job is, well, ah, you're learning.  :doh:
3. Get the whole thing in the guitar, ground the bridge, string it up, plug it in.
4. Then you'll know if you've got a quiet guitar or not. don't plug a pickguard into an amp!  :-\
5. If it's still noisy but the pickups do work, go back through and check your wiring, follow the paths to ground.
That's about it, hope it helps.
