Can anyone give me the name of a phaser which can power other effects by daisy chain power. Also if could be terribly rude and ask if you could then list the makes it would be able to power.
I dont' know of any effects pedals that power others. Boss makes a few utility style pedals that will. like their Tuner and Line Switcher, but no effects. Is getting a daisy chain and an adapter out of the question? 1 spot makes a great adapter that will power as many pedals as you can chain together.
I've seen a few that will do it, but those have severely limited how much power could be drawn downstream. I've not seen any that will directly power downstream devices; they're simply willing to share the incoming power. For instance, the Boss TU-3 tuner will daisy chain.
Normally, you use a power supply with a long line of parallel outputs. How long is up for grabs, as it's impossible to say how much each device is going to draw, so you can't predict how many devices the supply can support. Too many and you'll either burn up the supply or the devices won't get as much power as they want and so won't behave themselves. From what I understand, the One Spot comes highly recommended.
