Greetings! First post, first build, old player. Be gentle... :icon_biggrin:
I followed a diagram I found in the sticky and threw in a few modifications using the parts I`ve ordered. Monkey see, monkey draw, basically.
The vol and tone pot should split the neck and bridge humbucker, respectively, when pulled. I have no idea if the inner or outer coils are staying active with this setup.
Im not sure I put the treble bleed on the right spot either, and worried about having the pickupselector wiring wrong. :help:
If someone could chime in, I could start soldering without doubting what im gonna end up with. :sad:
EDIT: Color coding is useful! Corrected the jack tip wire.
Black: north start Dotted grey: north finish Red: south finish Green: south start
