ChrisMC
Does anybody know? I know they make the thickness for a 5 way blade switch a little thinner so the blade functions properly, and I’ve seen some pics that showed the holes for the potentiometers and just eyeballing it, it seems to be maybe 3/8’s inch or so, but just curious how much material they left for the control route and for the jack hole on the Soloist bodies.
I did confirm that long shaft pots are recommended unless you want to Dremel out some material where the pots are going to go, so you know they left a decent thickness there, just wondering if anybody knew what it was.
*** This question is specifically for the flat top Soloists, but if anybody knows both the flat top and carved top specs, go ahead and throw that in the ring as well.
