Rickgrxbass
As the subject leads on, I recently bought a pair of p-rails for my PRS Swamp Ash Special (HSH pickup array) (I know, it's not a W, boo!). I happened upon a spare push-pull pot from another project (probably my first mistake) to substitute for the standard volume pot, resulting in 2 push/pull pots and a 5-way blade switch. I promptly wired up the p-rails per SD's suggested "all 4 sound" schematic, re-strung and discovered that not only did I wire the outer pickups backward to the switch, I had also broken loose the middle pickup, and wired the tone cap to the hot lug of the volume pot instead of the ground...
tl;dr I think I fried one or both of the push-pull pots so I need replacement parts.
What I was thinking, was to take the stock wiring:
-strat-style 5-way +coil tap for humbuckers
And with no exterior mods to this modestly expensive guitar with modestly decent resale value, go to:
-PRS-stlye 5-way blade +middle pickup on/off push/pull, and maybe a treble bleed while I'm in there
Any thoughts? I know this will reduce the total number of sounds available, but the ones it will provide I feel will be ideal for most playing situations I can think of. If I didn't care about eventually selling this guitar, I'd break out my dremel and add another 3-way blade, ala PRS 513 to provide, well, 13 different sounds, but 10 or so isn't too shabby either.
