bagman67
Epic Member
Okay, time for a lesson in wiring. I knew it would eventually come to this - I'm planning to start assembling my telecaster (not the "Best Wife EVAR" one, the other one) and I'm looking at the following:
A Duncan Phat Cat neck pickup
A Duncan Quarter Pound Tele bridge pickup with a factory coil tap
A pair of 250k pots
A 1/4" OUTPUT (not input) jack
I'm planning the following switching options, and two possible variations, depending on whether I can source a three-hole Tele control plate (or get someone to drill a two-hole plate with a third hole).
Four-way switch should provide:
Neck only
Neck+bridge (parallel)
Neck+bridge (series)
Bridge-only
Now, either a miniswitch or a push-pull switching pot will engage the coil tap.
There are lots of instructions for how to wire the 4-way, so I'm not worried about finding something workable on the Duncan site, for example.
I guess what I'm wondering is: apart from the obvious issues of wiring the dang thing CORRECTLY, and soldering it cleanly and with solid, shiny joints,
WHAT ELSE DO I NEED TO BE SCRUPULOUSLY FREAKED OUT ABOUT GETTING RIGHT?
A pair of 250k pots
Neck only
Bridge-only
