MajorMattMason
Hoping I can get some help from you guitar demigods out there (Stratamania, are you there? :dontknow
I just received a beautiful MK satin finished 7/8 T-Style chambered body and the neck pick up pocket rout doesn't seem to feed into the control cavity.
The rout hole in the neck pickup pocket seems to go straight down about an inch and just stops.
If you feed a wire from the control cavity towards the neck pocket, it goes in about 4 inches and just stops.
Here's the weird part - if I shine an LED flashlight into the control cavity, there's a very faint amount of light shining up through the neck pup rout hole. If I reverse that process with the flashlight shining into the neck pup pocket, NO light makes its way into the control cavity. :tard:
I'm very reluctant do anything rash or ill-advised with power tools. Any ideas? Thanks in advance! :yourock:
