Cagey
Mythical Status
rkoeper said:pickup as an antenna - sure. That's the problem with single coils and no shielding will get rid of this. But shielding the cavities should get rid of any extra noise that would come in through unshielded wires, right? And at least for hum buckers that should be the major source of noise.
You would think. But, mean ol' Mr. Reality has shown us over and over again that it doesn't work. If you really want a quiet guitar, you need to shield the wires individually, and keep them as short as is practical.
The problem is that amplifiers (and special effects) have very high input impedances because the signals a guitar generates are very small. You need a brick wall for them to run into in order to drop any signal across an input stage. That makes them ultra-sensitive.
You can see it in action if you've ever played with an oscilloscope. They typically have input impedances that are in excess of 10MΩ, so all you have to do is touch the end of the probe with your finger and you can see the large voltages induced in your body from the magnetic fields in the surrounding environment. If you set the trigger right to make the waveform seem to stand still, you can also see all the harmonics riding on that wave, which are of higher frequencies that can sneak into smaller openings in your shielding. It may not sound like a higher frequency when it gets amplified because you're only hearing single cycles riding on a lower frequency, so it comes through sounding like 60hz hum, but that's what it is.
