double A said:
I would really like to know how they got those neck screws to bite and hold.
That's a good question. But, necks don't have as much tension on them as one might imagine. In the video, they talk about 250lbs of pull, but I can't imagine where they got that number. Most folks play with either 9s or 10s, and the pull on those runs from 80 to 110 pounds total, depending on the gauge set mix. Also, the pull is roughly 90 degrees to the neck length, so it's a shear load rather than a torsional load, which is much easier to manage.
On an electric guitar, a super-tight neck joint is desirable more for close-coupling to the body to add its inertia than tolerating mechanical stress. That's why bolt-on necks often have more sustain and rarely break while glue-ons are somewhat more subdued and break all the time. Mechanical fasteners make for tighter, stronger joints than a layer of reconstituted cattle skin.
