BrotherJack
So, I am still at my mad wiring experiments, and wanted to know before I order a switch: Can I use a single pole to coil split 2 pickups? In other words, the wires coming out of my pickup are like so:
-> ground wire and black wire we connect to ground
-> green wire to output/hot
-> red+white wires soldered together and we short these to ground (or not) to shut off one coil (or not).
If I have two pickups but only one spare pole on my switch, if I have both red+white pairs connected to that single pole (and thus touching each other), will them touching each other have undesirable results (such as possibly permanently coil split situation), Or will it be 'pickups work as usual, unless we put switch into position to short the coil split wires to ground?'
One answer is a $15 switch, one is a $4 switch.
Thanks in advance for your consideration and answers.
