I'm planning on building a guitar with a Strat body, and two humbuckers:
-Neck: Dimarzio DP227 Liquifire http://www.dimarzio.com/pickups/humbuckers/liquifire
-Bridge: Dimarzio DP166 The Breed http://www.dimarzio.com/pickups/humbuckers/high-power/breed-bridge
Also, I'll be wiring a 3-way switch, 1 Volume pot, and 1 Push-Pull Tone for Split-Coil, shown in this diagram: http://www.dimarzio.com/sites/default/files/diagrams/2h1v1pptsplit_3w_all.pdf
(In other words, a control scheme like that of the Ibanez JS series)
However, the control routing for Strat bodies only allow for 1 volume, 2 tones, and a 5-way switch. Would I be able to omit the "5-way switch" rout and just use the "Tone 2" rout for a 3-way toggle, OR should I just rout the body for 1 Volume, 1 Tone, and the 5-way switch (placing a 3-way blade/lever instead)?
