TBurst Std
Planning a future build as cash is tight to complete the current builds.
Neck back and body will be black korina.
I was fortunate in that someone offered so send me some black korina cuts that I can test on.
The plan restrictions:
I finish it myself, indoor job, not humidity of heat sensitive (I live in FL), no sprayer available.
Is my order OK, (leaving out the sanding between steps only from the listing below for clarity sake) and where these is A or B, pick one.
1. Prep the wood
2. Seal it: choices of A: thinned Tru-Oil or B; thinned Shellac
3. Grain fill (this is where I will test different fills. Clear with ZPoxy, Walnut with Timbermate, Black with Timbermate. Not sure if I want to try the Tru-Oil slurry method)
4. Seal the filler using A or B from step 2
5. Build a film layer using A or B from step 2
Looking to achieve gloss finish on body and satin on neck back.
Thoughts
1. Prep the wood
Thoughts
