Question for my fellow 5-stringers.
I am finally putting the finishing touches on my Warmoth Deluxe 5, and made an interesting discovery ....
The body is set up for string-thru. I have been using Ernie Ball bass strings since I began playing bass almost 15 years ago (talk about brand loyalty!), but have discovered that the "B" and "E" strings are tapered at the top, and when I run the strings through the body, the tapers do not quite make it past the nut! If I string the bass through the bridge (like all of my other basses), the problem doesn't exist.
So, my question is very simply ... which strings do you guys and gals use to go thru-body?
