Pelagaard
For my next project I plan to make either a fretless 4, or replace my 5, and either way, I'd like to use a J neck pup and a MM bridge. I plan to wire it so the MM can be split with a push/pull vol knob, and the J will have it's own vol. Not sure yet about passive vs. active, but in either case my question is: Which position (bridge or sweet spot) will give me the closest to the classic J sound when the MM iis split?
That explanation made sense in my head, let me know if I need to clarify (lots of lacquer fumes recently).
