Hello everyone. I'm not sure anybody else posted it: I've checked about a third of the pages dedicated to the suggestion box and didn't find anything similar, so: apologies if I'm repeating someone else's suggestion.
I'm on the lookout for a 7-string baritone Strat-type guitar. Not one for metal, but one that would allow me to play a bass-line into a looper before playing my chords and lead lines on the high strings over the loop. I very much like Warmoth's baritone 7 neck as its length is nearly exactly 2 frets above a standard 25.5in Fender neck, and that makes it really easy to transpose the D'Addario tension charts for my string selection (I'm after a light top-heavy bottom combination for ease of playability on the upper strings and intonation on the lower ones: existing 7-strings tend to use light-ish strings at the low end and I can't imagine them keeping the intonation particularly well, especially as they rarely go above 27in scale, i.e. only one fret above the standard Fender scale).
Now, for all intents and purposes a 60's P-bass looks a lot like a scaled up Strat (it's a compromise I could live with if I pick the right colour), and its neck pocket is only 1/8in narrower than the Baritone 7. Also, as the lower cutaway comes in pretty straight onto the neck, so the reduced material should not cause many problems in terms of joint stability. And Warmoth has the routing program for the baritone 7 pocket and (crucially) bridge, anyway... not to mention the program for a P-bass body.
Can it be done? I'm not mad keen on the two available 7-string bodies as they look a bit too "boutique", but if this mod was available there would be a whole new range of potential Frankensteins (I'd have thought that the J-bass would be suitable too, although more bass-looking...) to entice customers... or maybe not enough customers? But surely, once they have the CNC programs merged to suit, it becomes just another option available.
Any thoughts?
Any thoughts?
