Apologies in advance......newbie damn question
KaiserSoze
I'm sorry but I can't find the answer.  Will any necks other than the strat necks work on my new strat body.?  ie a warmoth model neck?  or a jazzmaster?  LP even?
Is the body from Fender? If so, then yes.
But anyway, there's a pretty handy FAQ with dimensions so you can measure before you order:
http://www.warmoth.com/Guitar/Necks/faq2.aspx
Yep, they will work - as long as the neck heel is a strat style heel.  I believe that the only case where it's not by default is if you buy a tele headstock neck.
Yes they will. Every neck except the telecaster will work on a strat body. Even the baritones and the 7 strings.
Wow, thanks.  Its a Warmoth body but I'm doing and SG-ish strat and the warmoth neck looked attractive.  The LP would cross into too-cheesy I think.
W necks look cool but a bit too close to PRS maybe, you could also consider a variax head, that's a nice simple headstock.
