Jusatele
find someone with a old Tube Driver, they are great, you may need to replace the tube and when you do get a few as they different last letters all sound different. Oh it is a 120 volt pedal so you will need a 120 feed to your board. You can find them for just over a hundred but the best examples usually are 1.5. I got one years ago and have sent it back to have it upgraded, the guy with the design rights still works on them for you. They use a real tube and rectifier to form a real preamp. works great with more boost than a siberian bear mounted drama queen on a 3 week cocaine bender.
you can get them to emulate a lot of different tube distortion if you find a 4 knob one. Good Luck.
he will make you a new one starting from 299, and he will even put in a 5th control for variable bias
