W
Watershed
Or is there a way to minimize this effect?
It's analine black dye (diluted in denatured alcohol) applied with a rag.
Washed back with denatured alcohol on a rag.
Sanded back with 320 just enough to get the hard strips/stripes of maple back.
Then a light mix of MEK Blue in nitro sprayed.
Washed back (rag) with thinner, light sanding with 400.
Spray clear
Looking directly at it, it's even.
A few degrees from center, and a rather strong contrast in shade between the two pieces of maple shows up.
I realize it's the grain of the wood, bookmatched, angle of the light in relation to the fibers, and so on.
But is there a way of applying the color to minimize the contrast in shade between the two pieces at indirect angles?
This is my third time around with this top varying the application and technique, and the same contrast is always there.
I had the MEK much darker, same thing pretty much.
Any help from the experts on this one?
James
Spray clear
James
