Hey everyone. I am just a few weeks from graduating from college, and as things wind down I decided I wanted a little project. Rather than bust out all my tools and templates and all that, I just had Warmoth do most of the work and got myself a routed body blank. The goal of this build is just to relax and have some fun doing some woodworking. As such, I will be doing nothing high stress, which to me is routing and all the finicky aligning of templates. I had Warmoth do all the hard stuff, I get to do the fun stuff.
Here is what we started with, a 2 piece alder blank.
Nothing happens without a good centerline, fortunately a 2-piece body makes this easy.
Here is the outline we are going for. It is the design from the plans by Martin Koch. A pretty cool little shape.
How I went about plotting the outline. I cut it down the centerline, then cut a little viewing space right were the neck pocket starts and lined it up.
After doing both sides you get a little something like this, sorry the picture is screwy, the pencil was pretty light as it is really just a guide.
I go over it again and make any adjustments I want. In reality, when I sand the outline to shape will be when I actually finalize the shape, this is more of a guide.
Probably the first thing I should have checked, but I also threw the outline on the back to make sure the control cavity was going to fit. I was also surprised to see that the screw holes for the cavity cover were drilled already. Is this something new Warmoth does? My old bodies never had them drilled.
Updates when I get this guy cut out.
