Jumble Jumble
I've been doing some experiments with this for a future blog article. It's possible... kinda.
If you want an either/or switching system then it's a piece of cake. If you want to have both pickups active at the same time, not so much.
The best results I've had so far come from having each pickup wired not only to its own volume control, but to its own output jack. Keep everything separate, including separate amps. At this point you can mix the sounds beautifully. The three-way swithc in this instance just mutes the output you're not using.
Of course this also allows you to put different effects on the different pickups. I've done a video here where I had the active pickup distorted and the passive pickup clean. It gives you amazing control between a clean and distorted sound. You could even replace the volume controls with a single 500/25 blend pot for easier blending of the two sounds.
[flash=853,480]http://www.youtube.com/v/fcooA3rrcPw?version=3&hl=en_US&rel=0[/flash]
I'm not going to keep the guitar wired like this - it's my most "normal" strat usually, 3 passive single coils, and I need it that way. I just used it for this because it has the swimming pool rout so it's easy to fit the battery and weird wiring in.
I did think it was interesting and fun though.
