Ok, when I first set out on this project a while ago the idea was to make a bridge that looked like an acoustic bridge but work with the saddles from a Strat. Also, this was intended to be installed on a hardtail Strat with single humbucker and rear rout. Since I haven't got around to doing my scratch build I decided to give it a go on one of my MIM strats. I knew that it would look a little "Bulky" due to the fact that I had to use the 6 hole mounting therefore making the whole bridge about 3/8" deeper.
I've made one before but was unhappy with the way our copy router routed out the center, it has a lot of grooves that will require quite a bit of work to smooth it out. So I contacted Doug....Mr. DangerousR6 and asked if he could use the CNC to do the center cut out in hopes that it would produce a smoother finish than our copy router. Doug did a fantastic job, dimensions were spot on and it only required some slight sanding with 600 grit paper and it polished right up.
Overall I'm happy with the way it turned out, I still have some "tweaking" to do...such as, I'll change out the factory intonation screws with some socket head screws counter sunk flush with the back of the bridge. Once I receive my block aluminum I'll be making a beefy trem block to go along with the bridge. I was on a roll and from start to finish I had around 4 hours and that included layout and drilling all the holes and hand shaping, sanding and polishing. Here are a couple pics of the process.
