I would suggest, if you aren't against experimentation, getting a raw neck. I would guess most necks you have played are either Maple/Maple, Maple/Rosewood, or Mahogany/rosewood. Typical combination s of Fenders, Gibsons, etc.
A raw neck from Warmoth may seem more expensive at first, but with frets installed, a pre-cut slotted nut installed... It's about the same price as if you bought a Maple neck with all those things + the expensive finish. A raw neck is woods such as Rosewood, Wenge, Goncalo Alves, Afra, Bubinba, Pau Ferro, Canary (Similar to the sound of a maple neck), Purpleheart, Padouk, Bocote, Cocobolo, Satine, Bloodwood, or Ziricote. I think I got them all.
Anyways, a neck made out of those woods (Lets say, a Goncalo neck shaft with an Ebony fretboard) will require no finish. It may sound off putting at first, but I find these necks easier to play on, and they feel faster. Plus, the raw wood feels surprisingly good, especially once you're used to it. You can bet your arse you'll be the only one in the area with an exotic neck, too.  :icon_thumright:
