The width on my Modulus is 1.85'', which is pretty damn skinny....
IMHO the THICKNESS of the neck has more to do with comfort than nut width.
You might be able to swing a thinner width, but just keep in mind that the thinner the nut is,
the more the neck has to taper to accommodate a decent width for the right hand.
This can goof you up as you play up the neck, which now looks more like an arrow,
as well as needing a compound radius board to prevent excessive buzzing....
Whew.... :icon_biggrin:
Another thought: Since W's necks are "steel reinforced" for the most part, how thin, front to back, can they go?
