Hi there, this is my first post here, been playing since I was 13, about 12 years now then. I'm currently working on my second partscaster, this time a Tele. I am planning on a 4-way switch but have some questions about the wiring. I attached the wiring diagram below. I am planning on putting a P-90 in the neck (which I will remove the stock cover and put a gold metal cover on it) and standard Tele Bridge pickup, both Lollars. So on this diagram below it states that the cover must be ground separately. How should I go about doing this? I'm quite confused on what exactly has to be done to make this work and would rather get it right the first time instead of trying something then having to take it apart again, although that seems a lot easier with a Tele than Strat! Thanks!
