reluctant-builder
Hi, all. I've got GAS. Been keeping me up, lately. I want to buy something, build something, tinker with something.
I've been thinking of a Strat with three P-90s, a 5-way blade Switch / 1 Volume and 1 Tone that is an On-On Push/Pull pot for the "Magnificent Seven" mod, adding the options for Bridge + Neck, and all three pickups at once.
I took a Seymour Duncan 3 single-coil wiring diagram and modified it. It's backwards because I'm a lefty. I plan on shielding the pickguard, so the pots will be linked that way, and with solder lugs with a bus wire running to the jack ground. The tags normally grounded to the backs of the pots would also be bused to the jack ground. I know those representations are missing, so please don't think of those as a grounding faux pas.
My questions are whether the diagram makes sense, otherwise. Do the hot wires go to the right places? Is the On-On represented in a way that would make it behave as desired (Bridge + Neck, All Three)?
Thanks.
Thanks.
