I had a question about the wiring of three single coil noisless pickups. The pickups In question would be a Dimarzio Area 58 for the neck, Dimarzio Area 67 in the middle, and a Dimarzio Area 61 In the bridge. All three pickups have 4 Conductor wiring. So I assume you could split them.
I was wondering if it is possible with just a 5 way superswitch or megaswitch or something similar it is possible to get a combo like this?
And also would I have to flip the magnet or wire the middle pickup in a different way to get hum canceling on the 2 in between sounds?
I was wondering this because it would kind of be like adding 2 different single coil voiced humbuckers for a total of 5 different single coil voiced humbuckers. I realize that since the coils wouldnt be tottally symetrical there would be a bit of noise. I like it when all of positions are around the same volume level so I wouldnt like having 2 of the single coil voiced humbuckers together at the same time as per normal wiring. I know I could probabbly do a 3 way switch and not worry about the in between sounds but I like that it would give some extra sounds.
Thanks for the help
Thanks for the help
