jim peters said:
What is the point of removing a mass of wood right in one of the most critical areas and placing metal in there?
WHAT ..... and they don't do anything like that when using a Tremolo do they :doh:
:icon_scratch:
Think you will find a Tremolo rout of ANY kind, especially when recessed ...... has a lot MORE wood removed than a 2TEK rout.
Sure looks like it to me !!
You measure a Tremolo Rout area ..... and I'll measure the 2TEK routed area ..... bet I win :icon_biggrin:
jim peters said:
All you are going to do is make the sound brighter and more tin like.
Great :blob7: ....... just what I'm looking for, with these ballsy SD Invaders :icon_thumright:
** Back to OP Q's
I have just mounted the 2TEK on a SG Body (No 2Tek mounting ring used)
By looking at it now, the wires from a Ghost saddle coming out the front would hardly be visible.
But .... if I was installing those Ghost saddles on this body.
I would be sending the wires into the 2Tek cavity and then though the back wall closest to bridge humbucker.
And into the humbucker pup rout then into the control cavity.
Like where I have sent the earth wire for the 2Tek.
Not much room on either sides of 2Tek cavity, when the unit is installed.
I don't know how big the plug ends are on those ghost saddles. :dontknow:
Just need a drill hole larger enough for those to fit though.
