ForgotYa
Hey there, new here and looking to do a PartsJazzmaster of sorts...
I'm looking in the Showcase and in the pulldown menu the 2Tek isn't listed as an option. Warmoth offers 2Tek routing, even on bodies already painted that you may already own. This tells me it should be available on any body on the site, Showcase or not, finished or not...
I don't know what to do because there's something I want, but can't pull the trigger because I don't know if I'll be stuck with something that I won't have the 2Tek option with and Warmoth doesn't open until Mon. so I can't call or email. Should I buy it and then call on Mon.? Should what I'm asking be possible?
I'm further frustrated because I called to buy something when they had the Warpaint sale recently and was told I couldn't get that option because the body was already painted....well, the body I'm looking at now isn't painted and I still can't get it. Also, as said before, if they do 2Tek routing service on something already owned it should be possible and available. This is not good as I could have saved a ton of money.
I'd like to ask about a couple more options...is what's on the site all that's possible? For instance, I'd like a Jaguar body, but the bridge moved to the Jazzmaster spot. The only difference is really the holes in the body for the control plates right? Should be easily done or will I just have to order a Jazzy body and put more holes in it?
Do they offer any other Pickguard options....for instance, a third hole for another volume control? The site only allows two holes.
If I end up having to order custom, is there anything I can do to get a light weight body? In googling it I saw they were offering it at one point, but I went through the whole options list and didn't see anything. Also, in the Showcase, lighter bodies seem to be more expensive? I see very similar bodies with randomly different prices.
Thanks so much in advance!
