Dan0 said:
You can split the coil with a tele 3way blade switch. I know it being active it's a bit different but I'm almost certain it's not a problem I'll look up emgs to make sure but unless you need 2 poles to do the splitting for god knows what reason you don't need another switch to do it.
edit: wow emg doesn't like simplicity i guess. and yes i believe a tele switch will fit into a strat route. hang in there and i'll post a diagram for a strat 3-way to go 1-bridge 2-neck 3-neck split. i think it's posible if you only have a single volume. or do you want 2 volumes?
Emg's are not meant to be simple, but they aren't hard to wire. Don't go by the manual, find better diagrams online.
And if you haven't already bought the pickups, listen to blackout comparisons on the tube. I personally think they sound more real, I love them.
