This will be my 5th Warmoth based project, previous attempts where as follows:
1. Jazzcaster (before they made them as a standard body you could custom order them which is what I did about 8 years ago. Marginally succesful with a swampash body, mitie might maple neck, Fender Tele bridge and duncan tele PUPs.
I can't find any pictures of this one
2. Thinline Tele (no f hole), swap ash body, fender neck this time and 2 x gibson pups from a LP studio. This was the one massive faliure as the pups did not work well with the guitar, I also tried a pearly gates (bridge) and that was not any better
3. I next built a chambered tele, with a swamp ash core and quilt maple top. again a fender neck was used with Bare Knuckle Country Boy tele pups. This worked really well but I didn't like the flashy maple top, not my thing.
4. So I went back to basics (inspired by the Fender Custom Shop 52 Thinline) I had a Swamp ash thinline body made, finished in butterscotch blonde and swapped the neck and electrics from the cambered Tele.
As you can probably guess I do swap and change about a bit.
Now project number five...
I already have the following:
original 1990's Jag-Stang neck inc tuners
Mustang control plate and bridge/vibrato
Seymour Duncan Custom Custom HB
Mustang neck single coil
500k push pull pot
My intention for number five is to build a Jag-Stang inspired at least visually by the Thurston Moore signature Jazzmaster.
So in addition to a transparent green finish I will also be getting a matt black pickguard.
Like Thurston I'll go with 1 pot for volume and use the extra hole in the control plate for a LP style toggle switch and therefore have no switches above the PUPs, as they've always got in my way on Jag-Stangs and Mustangs.
This all sounds like I have it all sorted out, but 2 things are bugging me.
- Do I get Warmoth to do the finishing for me or do I attempt it myself.
- Although I already have the mustang bridge and tail piece I'm not 100% committed. The alternative bridge that I think will work quite well is the bridge off a Fender Toronado (original version, pictured below). I would not attempt to fit the bridge myself as I don't have the necessary tools (drill press) to do this myself, so I would be getting a local luthier to do this for me.
Personally I am leaning towards the mustang bridge and a Warmoth finish.
Thanks in advance for any input anyone cares to put forward 8)
500k push pull pot
