1/2 Gallon
DarkPenguin
There was 1/2 gallon of water in my furnace. He seemed impressed.
I'm on a service contract with reminder phone calls and whatnot now.
"He" being the furnace repair guy and not the 1/2 gallon of water. The water was largely inert with no apparent emotion one way or another about being found in my furnace.
Apparently annual maintenance means maintenance you should have done annually. Not every half decade or so.
You may already know this, but if you have central air conditioning, then the evaporator coil is inside your furnace. They generally produce anywhere from some to a lot of condensate from the air in normal operation, depending on the relative humidity, so there's a capture tray underneath them to catch that water and drain it away so it doesn't rot your furnace. The tray has a drain that runs out of the furnace and into a nearby sewer drain if the furnace is in a basement, or somewhere outside otherwise. The drain line is small and the water flow is low and slow, so it often gets plugged up with unmentionable kukka like mold/mildew/algae/legionnaires disease, etc.
They're not precision things and aren't always installed with the greatest of care, so it's not unusual for there to be a bit of standing water in them, but it's usually more like a bit of a puddle than anything else. Typically, what doesn't drain will simply evaporate in relatively short order. A half-gallon in there would be a lot, indicating that the drain line is plugged.
Hopefully, he cleared that line for you, and told you how to keep it from getting plugged again.
My air conditioner is roof-mounted, so when the drain on it plugged the condensate ended up in the floor in the hall below the return air duct. I've heard it said that the vast majority of home maintenance is keeping water in where you want it and out of where you don't. Seems to prove out....
What kind of situation are you in where the A/C unit is mounted on the roof?
Interesting. I'm not an HVAC guy, but I would think that would be the worst place you could put the compressor/condenser unit unless you had no choice, like many commercial buildings are forced to. That part of the system needs to get rid of the heat it pulls out of the building interior, so it seems like you wouldn't want to put the heat exchanger in the hottest spot where little exchange can take place. Here in Michigan, if at all possible, you do your best to locate those units on the ground on the north side of the building where they're out of the sun. They'll still work anywhere else, they're just less efficient.
Yeah, I can count all of the advantages I know of a rooftop installation on... zero fingers. Limits efficiency by being in (very) direct sunlight as you point out, is a pain to access for maintenance, and replacing the unit poses a risk of creating new roof leaks. But, it's excellent at getting condensate on the floor in the hallway...  :dontknow:  You see it all over around here though.
I should think there would be less rattlesnakes in the unit when it is on the roof which might be of importance to the HVAC guy.
This is true. From a pros/cons perspective, not encountering snakes could be considered to cancel out the hassle of needing an extension ladder for access... the chart must be revised!
    My dad is a retired HVAC man.  He took care of all the movie theaters in town so he was up on roofs a lot.  He never fell off, but he knew some less attentive people who did.  The cool thing about that was that he'd always catch a free movie.  If he saw something he liked he'd take me later in the week to see it.  It's how he ended up taking me to my first in-theater R rated movie: "Aliens".
Old school FL also. Terazza floors, roof mounted ACs, pebble roofs.  Circa late 50s/early 60s
