TonyFlyingSquirrel
Master Member
It played like a dream
jay4321 said:[quote author=The Aaron]As a point of reference, we sell very, very few semi-recessed Wilky routs.
The Aaron said:A semi-recessed rout similar to the Wilkinson one could potentially work with a 510, because the studs would not have to be mounted in the recessed area. I personally find the semi-recess rout unattractive, but that's just me. Maybe we can explore that someday, but probably not soon.
stratamania said:If it helps anyone a Gotoh 510 will float on a Warmoth body and neck without recesses or neck shims. It will flutter easily and on one of the Warmoth's I have with a 510 I just checked and I can pull up so the open G goes up a minor third. If I was wanting to do more aggressive use I would be looking at using a Floyd of some type at that point.
rlefty said:Are you using a body with a pickguard?
rlefty said:For me it's more about keeping the neck overhang low and compensating with the semi-recess. It doesn't seem unreasonable to me; if you're going to float your trem at all, then having more space underneath it just leads to less body-banging.
stratamania said:Yes a strat-style body with a 510 (with a pickguard)
On a soloist with the 720 mod I can see where you are coming from. But see my earlier post in the thread about the Ibanez AZ, it is designed and built that way and has a shorter than normal trem block also.
- 510 route as i understand correctly will also be compatible with the new wilkinson trem with the locking saddles wich looks wonderfully (not tested yet).
any news on this consideration @aarontunes? i can also testify that the 510 works really fine with recessed guitars and if you have the recess you can do way more wonderful things with it (crazy upbends, setting up the trem a bit more backwards for more downpull throw etc.). the last guitar i had this on was a sterling petrucci which recessed cave fits perfectly the 510 without any wood operations. once you have the recess freedom you can use this thing really close to a floyd.
one more thought on the above statement that the wilkinson with the recess dont sell well, here some ideas why people better go with 510 if you have to chose:
- maybe its just me but the wilkinson vs 100 is way more ugly than the 510 in its various editons and will optically mismatch any classical appearing instrument while the 510 optically retrofits a fender bridge very good
- the gotoh comes in alot of different editions, the most important difference is that they offer 54mm string spacing and 52.5mm which is really cool, also further options of block type, saddles etc. are possible
so having this wonderful and modern trem supported fully with a fitting (semi-)recess would just be spectacular.
Does the semi recessed wilkinson route work with the 510 to provide more pull up range? Just a random thought on this after seeing this thread last week.It's not going to happen any time soon, and more than likely won't ever happen. The recess doesn't work with Warmoth bodies. We've already tried it. Because our trem cavities are made to be as universally compatible as possible they are routed slightly deeper. When we tried recessing the 510 the studs poked through the into the trem cavity.
One of the downsides of trying to be everything to everybody.
