How do you get the stuff like Goodfilla or Timbermate to be actually workable? They've been this dried out (and smelly), hard blocks inside the container. I've read to add water to thin it out, but it's almost impossible to rehydrate and stir. Even if I carve out a small chunk of it and put it in another container, it's still like hard clay that doesn't want to mix very well.I use the water-based grain filler these days (been buying Goodfilla). Water-based requires more work than the old oil-based stuff because it shrinks back more, but I don't have to worry about dangerous fumes and rags randomly bursting into flames.
Many people praise Z-pooxy, I plan to give it a try next time.
Lookin great!I just finished a mahogany body using Solarez grain filler and it worked great. Used Solarez I can’t believe it’s not lacquer to do the clear coat. Incredibly happy with the results.
First, there is NO SHRINKAGE which [undoes] the progress and requires multiple applications when anything with a carrier solvent (including water) is used.
Beautiful job! I too had some fisheye issues, contacted Solarez and was told to strain the liquid through a 120-mesh strainer from Harbor Freight. This got rid of tiny, hardened pieces of finish in the container. Their rep said this happens when the container date is near or past best by date. They sent me a new pint of the finish for free. The strained finish went on perfectly and no more fisheye issues. I use a portable grow house with 2 large UV lights for curing. This allows me to cure when the sun is not available. Got it and the lights on Amazon.I second JPOL's endorsemsnt of solarrez grain filler. I'll never use anything else. First, there is NO SHRINKAGE which undo's the progress and requires multiple applications when anything with a carrier solvent (including water) is used. Two part epoxy shares that advantage but puts you in a race against time as it cures. The solarrez has infinite working time without starting to gel up. I did an application at night and cured in the sun 12 hours later. Take all the time you want to spread it perfect. Then 5 minutes in the sun and its ready to sand. And, it sands so nicely- powders up so quickly and evenly.
This awesome grainfiller is not to be confused with the top coat from the same manufacturer, the horribly named "I can't believe its not lacquer". This I do not recommend. Someone here described in detail an ordeal involving tiny fisheyes and I had the exact same problem.
Here is 2 fills on a koa lam top and 1 fill on a walnut neck. The tiny dots on the body top are artifacts- there are zero open pores and its ready for shellac.
Here is a photo of my curing setup. The grow house is 3ft. x 3ft. x 6ft. The image was too large the first time.Greenhouse is a good idea IMO
