is it possible to use this 'schematic', if you can speak of one, to make a footswitch for my amp? when I got it, there wasn't a footswitch delivered.
This is what the manual itself says about the switching and footswitch.
manual rivera m100 said:Footswitch jack
The RIVERA(TM) FS-1 three function Illuminated footswitch (supplied) comes with a five-meter shielded 8-conductor cable. The connectors are 8-pin DIN plugs and jacks.
When FS-1 is connected to the Footswitch 1 jack, channel, reverb, and effects loop selection can be made through the footswitch. LED indicators on the footswitch, which correspond to their counterparts on the front panel, indicate when a function has been turned on.
When the FS-1 is connected to the Footswitch 2 jack, SLAVEMASTER, NINJA BOOST, and (in stereo models) CHORUS are footswitchable.
Additionally, there is an optional FS-2 footswitch available for monaural Combos for switching SLAVEMASTER and NINJA BOOST, and an FS-3 footswitch available for stereo Combos for switching SLAVEMASTER, NINJA BOOST, and CHORUS.
so if I get it correctly, I can use 2 fs1 switches for both jacks, to select them all? but still, I'd need to know how to solder the whole thing.
